Hello,
I’m Using the Fibaro FGD 211 with 2 LED Bulds. The system is diming well. If I switch of with a DIM of 20%, when I turn it on with the switch, it comes again to 20%, so the dtate is memorized.
is there a way to switch it on at the same rate with the Web UI of the Vera ? When I press On, it comes to 100%. I would like to have it at the last memorized state !
