I seem to be having issues controlling my ceiling lights (Fibaro Dimmer 2)
I am testing in my Kitchen room and the light is called “Ceiling Lights” in Vera UI7.
I am using Shortcuts in the Google Home app.
The following commands DO NOT work and the response from Vera Concierge is: NULL
ask vera concierge to change the ceiling lights to 25%
ask vera concierge to set ceiling lights to 25
ask vera concierge to change ceiling lights to 25
ask vera concierge to change ceiling lights to 25%
These commands DO work:
ask vera concierge to change the ceiling lights to High / Max / Bright
ask vera concierge to change the ceiling lights to Medium / Average
ask vera concierge to change the ceiling lights to Low / Dim
If I speak to Vera Concierge directly and ask:
It responds by asking me again what level? If I say 25% again it says what level? and so on in a loop.
I also have a similar problem trying to set the thermostats set point to a value.
I have tried the following commands in the Google Home app shortcuts:
ask vera concierge to set the thermostat to 10
ask vera concierge to set the thermostat heating set point to 10
“thermostat” being the actual name of the device in Vera which is called “thermostat”.
I setup my shortcut so I can say “turn off the heating” when I say this to the Google Home speaker, Vera Concierges response is NULL.
If I speak to Vera Concierge directly and say:
set thermostat to 10 - It says sorry I did not understand that
If instead I say:
set thermostat heating level to 10 - It says “what thermostat name?” I then say “thermostat” it then says “which thermostat?” I say “thermostat” it then says “what thermostat name?” on and on…
Thermostat commands can not have shortcuts … I did not register the app with those commands as “Initial” commands.
You can currently only do switch, dimmers, and locks as a one line command.
I am now able to control some basic things via GH / Concierge, like lights and appliance devices.
Currently running Vera scenes via GH / Concierge to turn the heating on / off which is fine as I just have the on scene set thermostat to 23 degrees and off scene to 10 degrees.
Is it possible to turn off Vera Concierges command feedback speak ? Its conflicting with my own TTS feedback announements I previously setup in Vera.
Thank you for your continued work and plugin development.
The percentages should work now.
DialogFlow (a google company that does the AI for voice recognition) did change how they use some system entities such as percentages.
[quote=“RichardTSchaefer, post:9, topic:197834”]The percentages should work now.
DialogFlow (a google company that does the AI for voice recognition) did change how they use some system entities such as percentages.[/quote]
Great I will try this again and report back later or tomorrow.
