So this will probably be fairly easy to answer and while I looked through the common example scripts I couldn’t find something that applied to my question. I don’t really have trouble with the scripting part, I just can’t figure out the logic of what I’m trying to accomplish, so here goes.
I’ve dumbed this way down to a very basic version of what I’m trying to do, but once I figure this out I should be able to figure out the rest as well.
I have 4 components - 2 lights (L1 & L2), 1 dimmer (DIM) and 1 scene controller (SC).
DIM is directly connected to L1 and turns it on or off regardless of scenes.
SC and L2 are not directly connected to any devices.
When I press DIM (ON/OFF) it triggers a scene that turns L2 ON/OFF (in addition to L1 which is directly connected)
When I press SC, I WANT it to turn OFF L1 while keeping L2 ON (or if L1/L2 is off, just turn on L2)
The problem = When I press SC, it turns OFF L1, which triggers the scene to turn OFF L2.
I obviously need to reconfigure my scenes and probably add some LuuP code, i’m just having a hard time with how that should happen and what conditions are needed.
My initial thoughts are this:
Create two scenes, one for DIM and one for SC
On DIM scene - IF L2 = off then run scene
On SC scene - IF L1 = on then run scene
I still feel like I have a loop in there though.
Any help?
