As part of our complete kitchen remodel, we had the electrical re-done including all new lights, switches, etc. Decided to go with a VeraEdge and Leviton switches for this first home automation set up. I was able to successfully add each Leviton switch and dimmer to the VeraEdge. I can properly control each device. I created 4 scenes:
[ol][li]All Lights[/li]
[li]Cooking Area Only[/li]
[li]Ceiling Fan[/li]
[li]Light Fixtures Only[/li][/ol]
All Lights scene is the one give me headaches. It controls the following switches dimmers:
[ul][li]Ceiling LEDs fixtures[/li]
[li]Two Light fixures (one is the ceiling fan light)[/li]
[li]Sink Light[/li]
[li]Under cabinet lights[/li][/ul]
If I trigger the scene via the Vera web interface, all of the lights come on. The Scene works as I want it. I programmed the scene to use button 1 on the VRCS4 scene controller and when I physically press it, everything comes on except the under cabinet lights. Button 4 lights up on the scene controller (not button 1 because the under cabinet lights are not on). Button 4 is for the two light fixtures and pressing that turns off those two but (as expected) doesn’t turn off anything else.
Not sure what I am doing wrong.
Initially, I had programmed button 4 to be All On and noticed that buttons 1 and 2 lit up. I am guessing that since the scene controller found the lights associated with buttons 1 and 2 on, the button light activated. I moved the scene to button 1 to see if that would alleviate that issue.
Feedback and guidance appreciated.
Al
