I can log into Mios.com but not Findvera.com when I am away from home.
Can some one explain the difference, and why I can log into one and not the other?
I’ve only had the Vera2 and UI4, so the only site available is cp.mios.com. It would appear that everything newer is going to route there eventually.
Short answer:
Findvera.com is for UI2 and UI3 users
Cp.mios.com is for UI4 users.
There is probably more to the story, but that is effectively what it means to us users.
[quote=“fall-line, post:3, topic:166557”]Short answer:
There is probably more to the story, but that is effectively what it means to us users.[/quote]Correct although if you are local to your Vera then going through findvera.com will still give you the option to correct directly to your Vera even if its running UI4
got it. I was wondering why the findvera site would never work for me. I was looking through the wiki today and found the mios site which works fine away from home.
@ Strangely wrote: Correct although if you are local to your Vera then going through findvera.com will still give you the option to correct directly to your Vera even if its running UI4
I have not been able to connect (ever) to findvera.com, local or otherwise. UI4 1.1.1047 & 1.1.992. Don’t know about other releases.
