Evolve LOM-15
For the two items above, there seem to be no reviews either on Amazon or elsewhere. Can anyone recommend one over the other? Has anyone used these yet?
Evolve LOM-15
Doh! Looks like the Evolve are not tamper resistant…
Came across this post. I’m looking into the Evolve and here’s my 2 cents versus these 2.
While one is tamper resistant, the necessity for me of purchasing the Evolve model is because it supports the command class scene and security compatible which in zwave terms is called beam command.
So, if you have one of the locks like Qwikset and you are just a bit far away from your controlling unit like a VeraLite, you might have a reliability issue with opening/closing the lock. This is because this lock must transmit encryption keys. A standard zwave device that says it is a “repeater” is uniquely different than being a repeater that supports command class/security compatible/beam. So the repeaters can’t send the encryption traffic thus requiring the command class to increase the range.
Don’t know about the receptacle, but the enerwave line is pretty much like GE but with instant status on the switches. I have their scene controller, which seems reasonably well made. But there are no set up variables at all. It seems with enerwave there’s no functionality beyond what is explicitly stated in its features.
I don’t see much reason to buy the enerwave receptacles based on price, but some of the other devices in that line are interesting. Especially as an alternative to ge switches and scene controller. Like GE, no neutral on the enerwave dimmer, which is a minus if neutral is available.
I have a few things to add to this discussion, I don’t have security set up yet, i’m waiting on a hidden door window sensor like the aeotec that is available in the EU market. So i have no need for beaming. Fut as far as the enerwave stuff…
With all that said i think they are better and more robut than GE, I dont have experience with the Evolve.
