First of all… Happy New Year to you all!!
Now my question.
I have a foscam FW8918 camera with motion detection.
The motion detection works fine, here no problem or question.
The question is when i add motion detection to a scene using a trigger.
When adding this trigger i have the option ‘when a armed sensor is triggered’ of ‘when a (xxxx) sensor is tripped’
Can please someone explain to me the difference between those 2 settings?
I use the camera motion sensor for 2 other scene’s
- for switching a spot light on a clock :), this only during specific time and when motion is detected, the light stays on for aprox 1200 seconds when motion is detected and switch of when no motion is detected anymore.
- switching my thermostat to ‘comfort’ when someone is in the room and back to ‘night’ when no one is present again.
The scene’s are setup using the ‘a sensor’ option, my question is what happens if i use ‘armed sensor’ instead.
I tried this once on the lighting but then the light never switched off again, so i do not understand the difference between the 2 settings.
Who can explain to me what and how to use exactly.
Thx!!!
