Devolo MT02755+ woring with Vera?
Hi guys,
Some time ago I’ve turned my back to Vera and migrated to Domoticz using an Aeotec z-Stick.
Now I’m considering to give Vera a second chance - as a z-wave controller only - in combination with HomeAssistant.
Before starting, I?m checking my device compability.
In my Bathrooms and on my Terrace, I?m using Devolo MT02755+ Temperature and Humidity Sensors. Is anyone using this device with Vera? It doesn?t appear in the compatible devices list. Are they working ok?
Thanks Dirk
This looks to be a rebranding of the Philio version which already works with Vera. We don’t have a sample of Devolo but there is a big chance it will work.
Thanks, that sounds promising.
Will give it a try on the weekend.
Thanks Dirk
I can confirm the devices are working ok!
Thanks Dirk
Thank you for the comeback, Dirk. Good to know.
