Hello,
I’m currently working on a logger that logs every state change to a database. I’ve noticed that when calling lu_sdata, a different number of properties for a device are returned depending on whether it is a ‘full’ response or partial. See the example below of what I mean:
Initial response:
stdClass Object
[name] => Washing Machine
[altid] => 10
[id] => 31
[category] => 3
[subcategory] => 0
[room] => 2
[parent] => 1
[status] => 1
[light] => 30
[kwh] => 30.2700
[state] => -1
[comment] =>
[watts] => 108.5
Incremental response:
stdClass Object
[altid] => 10
[id] => 31
[subcategory] => 0
[room] => 2
[parent] => 1
[status] => 1
[light] => 30
[kwh] => 30.2700
[state] => -1
[comment] =>
[watts] => 96.7
As you can see, the properties name and category are not present in the incremental response from Vera when the watts value changed. Is there a list of properties for each device I should expect to see returned? Will it only every be those properties missing above that are excluded from responses?
Thanks for the help
