Hello
I want to inform our community that we release to live Linux FW v.2.0.27.1916.1 for Ezlo Plus and Ezlo Secure (E450, E550) controllers that supports Z-wave device association.
To use device associations you should check your firmware version (and update it, if it is lower than v.2.0.25.1859.1) and unpair the devices from the controller and then pair them again.
We provide ability to manage Device Associations using our web app ezlogic.mios.com
Group 691488×665 86.5 KB
Go to Device Associations (1) page.
See the listing of existing associations (2). Each row contains 2 devices, source device (3.1) and target device (3.2). You can delete (4) existing association.
To create a new association, press “+ Create New Association” button (5), then select Source Device (6), its Channel (7) and Group (8) and then Target device (9) and press Save Association button (11) or you can delete (10) this row.
Note: if you select a Source Device and do not see any other dropdowns there could be some reasons:
- Outdated Firmware version.
- Device does not support associations.
