What is the proven way to get the device options (variables) to update. I struggled with my fgd211 for ages… Requested value was set as I want but the current value stays empty. Eventually I switched the power off at my mains and it seems to have worked. Is this the best way to acheive the change?
John
UI5 or UI7 ?
How are you determining that variables are not changing ?
Set your variables in device options make sure to actually click Save Changes
Back out and go to the Advance tab then Commands tab then click “configure node right now”
Back out and go back to the device options tab and verify the value took.
If it doesn’t take, it often is because you picked the wrong Data Size option.
Thank you I will try that next time.
