Is there some way to delete a node without having the original device around?
Is there a database in Vera that can be accessed to do this?
Thanks!
Thanks!
You can delete the device on the Vera control panel.
But the device will still be part of the Z-Wave network until it is excluded.
The list of devices that are included in the Z-Wave network are stored in the Z-Wave dongle or daughter board. The tools to manipulate this data are:
[ul][li]Reset - Remove all data[/li]
[li]Include - Add a new device
Device must be present[/li]
[li]Exclude - Remove a device
[li]Restore from Z-Wave Backup
Restore to a previous configuration[/li][/ul]
If it was a recently included device … you may be able to remove it by restoring from a backup before it was included.
Thank you for that.
I have an Insteon Model 2420M but don’t know how to exclude it, using the set button.
You did not indicate Insteon … I assumed it was a Z-Wave device.
I do not use Insteon … So I am not sure of the configuration manipulation options.
