Delete Fibaro door device but keeping the temp device?
Hi, I am using the Fibaro door sensor with a DS18B20 as a pool temperature sensor. When i added my sensor it created two devices, one for the door sensing and one for the temperature. I am wondering if I can delete the door sensor edvice but keeping the temp device created in UI7, or will both be deleted?
I am also having trouble with my Geo fence not working properly, I have two iphones connected and i get the push messages saying enter/exiit as it should, but it does not set my mode to away when exiting, even though all settings are correct. “Home” mode is working properly.
/Corpze
If you delete the sensor you’ll lose everything. However, the door sensor and the temperature device should have different device numbers.
You should be able to set the unwanted device to Invisible, without affecting the temperature.
Hiding devices.
