I have a strange problem as follows:
I try to make a scene when I push “all lights out”, all the lights should be switched off after 1 minute (so you have time to leave the room etc…)
When I make this scene and manage the delay (put in on 60 secs) it all goes well, after saving, when I go back to this scene the delay is set back to “immediate”, and when I launch the scene, it is running instantly… So in short, I cant put any delays on my scenes
Any suggestions ?
Hisedase
UI5 on Vera Lite… Latest version firmware
You need to click on the drop down menu that says immediate and click on the value that you entered (60 seconds or 1 minute) and than click on the devices that you want to have turned off. Once that is done, you need to click on the save button. It sounds like you have the devices turning off for the immediate setting and not the delay one.
[quote=“garrettwp, post:4, topic:171517”]You need to click on the drop down menu that says immediate and click on the value that you entered (60 seconds or 1 minute) and than click on the devices that you want to have turned off. Once that is done, you need to click on the save button. It sounds like you have the devices turning off for the immediate setting and not the delay one.
And de-select your device in the immediate section. The immediate is the default delay for a scene. If you only want things to happen only have device states defined for that delay.
