Delay Switching on lights with a PIR Trigger
I have 2 Everpsring SP103’s and an HSP02 PIR’s with scenes set to trigger lights based on movement. All work as expected but I get around a 2 second delay from the sensor triggering to the lights switching. The lights are controlled either by Fibaro dimmers or relays. Is this normal ? Do i need to control the lights directly from the sensors ?
Thanks,
Neil
Got exactly the same issue in my downstairs loo. Takes a second for motion detector to instruct vera to instruct light.
I think direct associations are probably the way forward but a bit clueless. Gonna RTFM but any help guys would be appreciated!!
Thanks.
Sorry I should have said 20 seconds not 2 in my case.
