Hi @amg0
I discovered the ALTHue plugin due to problems I’m having with the Philips Hue 2 plugin after adding a Philips Hue Smart Plug to my network. I like the look of the ALTHue plugin and it seems to work just fine with the Hue Smart Plug. However, the light icons are all showing the default light bulb, not the SVG Hue lamp images.
I installed the plugin via the Install Apps menu on my Vera Edge and I’ve got app version 1.47. I used scp to copy the SVG files to /www/cmh/skins/default/img/devices/device_states and verified the files are there. After reading another post I’ve done a “restore to defaults” and restored from backup but still just the default icon showing. Any thoughts on what I might be doing wrong?
I’m using the default UI7 (not ALTUI) - Vera Edge firmware 1.7.4452
