I’ve had the cameras for several years now, but need to reconfigure for standalone as the Vera has failed. What is the default IP that a Vistacam HD camera gets after a factory reset?
Hi DietCoke,
The camera doesn’t get a default IP. In order to find it you should look at DHCP connections on your router. You should see all the IP assigned to all devices on your network.
All the Best,
- Andrei -
