I’m trying to set this up using the powerlink2 and an ethernet to RS232 console cable with a 232->USB connection.
I’ve tried a few different ways of installing and just can’t seem to get it to mesh with what I am seeing in the WIKI. Anyone else using the powerlink2?
So I blew it all up to factory default and it picked up the a few devices and then i only installed the plugin and set it to force standard mode.
Everything was going really well for about 10 minutes…then i got the Startup Error…it would allow me to Arm Home even though it was prompting for 4 digit pin code… I’m attaching zip with some screenshots & log.
A factory default won’t help. Best thing is to take off the power (mains and battery) to get the panel in the right state again.
Have look at the powermax_pdu.txt file. You’ll see that only once an acknowledge message comes back from the panel (‘0D 02 FD 0A’). Each message should be acknowledged, so communication is not flowing well.
Yes, your serial communication still does not work. Messages that are being sent are not being acknowledged that they have been received by the panel. You will need to describe your setup set-by-step to get any further (type of interfaces, cables, connected devices etc.).
Powermax Pro PC/IP Port - > Prolific PL-2303HX or HXA USB-to-Serial Bridge connected via (RX → TX, RX → TX, Gnd → Gnd on top row) → USB Type A Female to Male Cable - > Vera Lite
Running the Visonic Plugin from the Marketplace.
On a fresh restart it works for about 10 minutes in force standard mode, I tick all the sensors and their Zones and it pulls those across from the panel. It adds the second device for partition 1.
The Control Tab shows version 1.1 and standard mode and that is it. Nothing else comes across around the panel, version, eprom, etc.
I was able to Arm Home last night but that was it then the Lua Startup Fail…
root@MiOS_35010295:~# dmesg | grep “pl2303”
USB Serial support registered for pl2303
pl2303 2-1:1.0: pl2303 converter detected
usb 2-1: pl2303 converter now attached to ttyUSB0
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
usb 2-1: pl2303_read_int_callback - usb_submit_urb failed with result -19
pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
pl2303 2-1:1.0: device disconnected
Good that you looked at this! I already was afraid of this. But it clearly identifies the ‘PL2303’ as the problem. I’ve previously seen problems with PL2303s, hence I always use FTDI based devices. There are cheap rip-offs around of PL2303s. FTDI based ones are safe.
I have that already that I was using with the plink2, using a console cable. but with plink2 not working seems i have to get the visonic rs232 adapter?
