One of my leviton fan control switches randomly died today. I found the fan off when it was supposed to be on. So I hit the air gap on the switch to reboot it. Fan still wouldn’t come on. I hit the air gap switch again and left it without power for a good 15 minutes this time. When I switched it back on… now low speed and medium speed work locally… but when switched to high speed the fan just turns off.
I then factory reset the switch and it still acts the same way.
The big problem is…
Now it will not respond to zwave commands and it has a red configure gear in vera. So I think it is creating network problems.
I want to remove the switch from vera so it cannot cause network problems (the network should already be removed from the switch side by doing the factory reset). I tried the “permanantly remove dead node” button but the device is still there and vera is still trying to communicate with it. How can I get rid of this node from vera!?
