Hello,
I am a new veralite user.
I included a minimote with Vera, but i ve done a mistake.
It was not working properly…
So i decided to perform a reset of the minimote.
Now i have a kind of dead/empty device in the UI.
A _scene_controller device with device id, and ID set but no other informations.
I can not remove it.
but, If i re-include my minitmote that creates a new device ! (that still doesn t work)
Is there a way to remove this dead device from ?
Thansk a lot.
See, for example, the bottom line of this post
[url=http://forum.micasaverde.com/index.php/topic,14800.msg112308.html#msg112308]http://forum.micasaverde.com/index.php/topic,14800.msg112308.html#msg112308[/url]
Oh, i see, i will try that this evening when i come back home…
Thanks a lot.
Hello,
Yes the device has been removed from the UI.
For information, i still have a kind of ghost device that is displayed in the proposal device list when creating a trigger.
Thanks.
[quote=“bouder, post:4, topic:175615”]Hello,
Thanks.[/quote]
If you are referring to _scene_controller which has a device id of 2. This is normal as this is actually vera.
