I know the locks can trigger a scene when a code is entered, how about when a key is used to manually unlock or lock?
From the Triggers tab:
- Choose the device
- Choose “A door is locked or unlocked”
- Name the trigger
- Choose either:
- “Device is opened” for unlock
- “Device is closed” for lock
Don’t ask me why it doesn’t say “locked” or “unlocked” for the last test
[quote=“PurdueGuy, post:2, topic:173632”]From the Triggers tab:
- Choose the device
- Name the trigger
- Choose either:
Don’t ask me why it doesn’t say “locked” or “unlocked” for the last test[/quote]
Thank you. I have not bought a lock set as of yet. You have tried the key then?
I have Kwikset locks, and using the key is the same as throwing the latch inside (since the 2 are physically connected.
Vera gets the notifications and acts on them.
[quote=“PurdueGuy, post:4, topic:173632”]I have Kwikset locks, and using the key is the same as throwing the latch inside (since the 2 are physically connected.
Vera gets the notifications and acts on them.[/quote]
Perfect, again thanks.
