- There’s no way to edit notifications, you have to delete and re-add
- If the text of the notification contains an apostrophe, everything after the apostrophe is stripped off.
Are you using Vera’s standard notifications ? Or are you using the Vera Alerts plugin ?
Didn’t even know there was an alerts plugin… But I was using the notification that is on the device info for the day/night plugin.
The notifications tab is handled by Vera itself. So that behavior will be the same for all Devices.
The Vera Alerts plugin provides an alternate way to send alerts to your mobil device(s).
