Day of Week based Timers
I noticed this weekend that my day of the week timers are not following the schedule for which days are checked. I basically have two types of timers: weekdays and weekends. I noticed yesterday (Sat) before upgrading to 1.0.292, that the weekday timer was executed. Again this morning it executed again.
Can you go to advanced, tech support and enable verbose logging? Then the next time it fails, go to advanced, tech support and send in a trouble report along with the logs. I’ll see what went wrong
Yes, I also noticed today that my weekend timer was running, when it should not. >:(
HF, Chris
Can you try submitting a tech support request soon after the timer erroneously fails? Vera only keeps logs for a few hours because there’s not a lot of memory, but if you submit the support request soon after the failure I should be able to see from teh logs what went wrong.
An incident has been filed.
At least I think I did. :-[
After the first submit, nothing happened.
After the 2nd submit an “!” showed up above “Tech Support”.
Is that how it’s supposed to respond?
I would expect a response page, with confirmation… ???
HF, Chris
we’ll look into it: http://bugs.micasaverde.com/view.php?id=271
