DateTime Formatting Bug?
Richard,
I’m currently writing this in the message section of a standard vera alert notification: {DateTime(CurrentTime,%A %B %d, %Y at %H:%M)}
However, when I save the scene, run it, it says this, literally: {DateTime(CurrentTime, f i, d at m:>)}
When I go back in and check the scene, it looks like: {DateTime(CurrentTime, f i, d at m:>)}
{DateTime(CurrentTime %H:%M)} turns into {DateTime(CurrentTime s:h)}
I am on firmware version 1.7.3015 with VeraPlus. The weirdest thing is that I have this working on another scene, but I’m too afraid to start editing it because I may be in the same boat after I tinker with it. This all started a few days ago when I removed a little bit of text from the alert and saved.
Any thoughts?
I updated to the latest firmware. Still have the same issue. Now when I go to create a new scene with this DateTime format string in it, they don’t even show up on the scenes tab.
When I entered this into a vera alert notification: {tone:2}{BGColor:Green}Welcome home, Nathaniel. The local time is {DateTime(CurrentTime %H)}
This is what I got when I tailed /var/log/cmh/LuaUPnP.log:
01 02/27/18 19:49:14.100 sbrk JobHandler_LuaUPnP::HandleActionRequest Problem with getnameinfo <0x77285520>
08 02/27/18 19:49:14.101 JobHandler_LuaUPnP::HandleActionRequest device: 43 service: urn:richardgreen:serviceId:VeraAlert1 action: SendAlert <0x77285520>
08 02/27/18 19:49:14.101 JobHandler_LuaUPnP::HandleActionRequest argument Message={tone:2}{BGColor:Green}Welcome home, Nathaniel. The local time is {DateTime(CurrentTime e)} <0x77285520>
08 02/27/18 19:49:14.101 JobHandler_LuaUPnP::HandleActionRequest argument Recipients=nathaniel <0x77285520>
08 02/27/18 19:49:14.102 JobHandler_LuaUPnP::HandleActionRequest argument HouseModeMask= <0x77285520>
06 02/27/18 19:49:14.453 Device_Variable::m_szValue_set device: 43 service: urn:richardgreen:serviceId:VeraAlert1 variable: LastMsgSent was: 19:46:41 Tue Feb 27 now: 19:49:14 Tue Feb 27 #hooks: 0 upnp: 0 skip: 0 v:0x12d3348/NONE duplicate:0 <0x77e36320>
04 02/27/18 19:49:14.465 <0x77e36320>
Richard, are you alive, buddy? Got any words of wisdom for me?
I entered your time strings into “Send Alert Now” from Vera Alerts … all worked as expected.
The Send now function it works fine, Richard. Try creating a scene with it.
Richard, try creating an actual scene with it. It works fine in the “Send Alert Now,” but not in scenes.
