Thanks for the info akbooer
Tried to use graphs in the datayours dashboard but nothing came up
config showed
DataGraph CONFIGURATION at Sun Sep 25 12:52:58 2016
DAEMON = {
VERSION = “2016.01.04”,
client = “DataGraph”,
destinations = {},
errors = {
count = 4,
message = “ERROR: ./L_DataWhisper.lua:622: unable to open Whisper file ‘/etc/cmh-ludl/datayours0.wsp’”,
time = “Sun Sep 25 10:02:17 2016”
http = {received = 2},
ip = “xxx.xxx.xxx.xxx”,
start_time = “Sun Sep 25 08:49:47 2016”,
udp = {
last_received = {},
last_sent = {},
received = 0,
sent = 0
DATAGRAPH = {
stats = {
fetch = {
cpu = 0,
number = 0,
points = 0
plot = {
cpu = 0,
number = 0
whisper = “/etc/cmh-ludl/datayours”
[cache] = {
LOCAL_DATA_DIR = “/etc/cmh-ludl/datayours”,
UDP_RECEIVER_PORT = “2003”
[dash] = {
DATAMINE_DIR = “/etc/cmh-ludl/datayours”,
ICON_PATH = “/cmh/skins/default/img/devices/device_states/”,
VERAS = “”
[graph] = {
[mine] = {DATAMINE_DIR = “/etc/cmh-ludl/datayours”}
[relay] = {
DESTINATIONS = “127.0.0.1:2003”,
LINE_RECEIVER_PORT = “”,
LIVE_ENERGY_USAGE = “1”,
MEMORY_STATS = “1”,
SYSLOG = “”
DataWatcher CONFIGURATION at Sun Sep 25 12:55:49 2016
DAEMON = {
client = “DataWatcher”,
destinations = {“127.0.0.1:2003”},
errors = {count = 0},
http = {received = 3},
udp = {
last_received = {},
last_sent = {[“127.0.0.1:2003:inet”] = “Vera-88800127.10015.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage 0 1474800946”},
received = 0,
sent = 2344
DATAWATCHER = {
VERSION = “2016.04.09”,
live_energy_usage = {
[“Vera-88800127.10009.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“09 Power TV Master”,4},
[“Vera-88800127.10015.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“15 Lights Garden”,0},
[“Vera-88800127.10093.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“93 Shutters Dining Right”,0},
[“Vera-88800127.10104.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“104 RGBW Master”,0},
[“Vera-88800127.10123.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“101 Power TV Dining”,0},
[“Vera-88800127.10125.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“125 YouLess Energymeter”,495},
[“Vera-88800127.10134.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“134 Powernode Master”,0},
[“Vera-88800127.10135.urn:micasaverde-com:serviceId:EnergyMetering1.EnergyUsage”] = {“135 Powernode Seagate”,76}
memory_stats = {
MemAvail = 826412,
MemFree = “724660”,
MemUsed = 223448
tally = {
HTTP_relayed = {},
UDP_relayed = {},
watched = {[“10125.urn:micasaverde-com:serviceId:EnergyMetering1.Watts”] = 7}
translations = {}
[cache] = {
[dash] = {
VERAS = “”
[graph] = {
[relay] = {
MEMORY_STATS = “1”,
SYSLOG = “”
