AK,
Really changed nothing except doing a linux update and as often, grafana updated too!
[code]HTTP Web Server, Fri May 4 20:38:12 2018
Received connections:
IP address #connects date time
10.99.99.41 916 2018-05-04 20:33:15
10.99.99.42 694 2018-05-04 20:37:57
10.99.99.44 2747 2018-05-04 20:37:49
172.30.30.87 20 2018-05-04 14:43:45
172.18.18.11 395 2018-05-04 20:29:29
10.99.99.43 676 2018-05-04 20:37:19
10.99.99.20 12456 2018-05-04 20:38:12
/data_request?
id=… #requests status
action 5016 200
lr_ALTUI_Handler 17 200
lr_DataCache 1 200
lr_DataGraph 1 200
lr_DataWatcher 1 200
lr_DataWatcherRelay 6299 200
lu_action 2 200
lu_status2 5664 200
sdata 4 200
user_data 538 200
variableget 6273 200
CGI requests
URL #requests status
/console 4 200
/metrics/find 17 200
/metrics/index.json 1 200
File requests
filename #requests status
D_ALTUI.xml 6 200
D_AltAppStore.xml 6 200
D_BinaryLight1.xml 6 200
D_BinarySprinkler1_UI7.xml 6 200
D_BluetoothNetwork.xml 6 200
D_DSCAlarmPanel1.xml 6 200
D_DSCAlarmPartition2.xml 6 200
D_DataYours.xml 6 200
D_DayTime.xml 6 200
D_DeusExMachinaII1.xml 6 200
D_DimmableLight1.xml 6 200
D_DoorSensor1.xml 6 200
D_GenericIO1.xml 6 200
D_GenericSensor1.xml 6 200
D_HVAC_ZoneThermostat1.xml 6 200
D_HouseModes.xml 6 200
D_HumiditySensor1.xml 6 200
D_LightSensor1.xml 6 200
D_MString.xml 6 200
D_MSwitch.xml 6 200
D_MotionSensor1.xml 6 200
D_MyQGarageDoor1.xml 6 200
D_MyQGateway.xml 6 200
D_OpenSprinkler1.xml 6 200
D_PingSensor.xml 6 200
D_PowerMeter1.xml 6 200
D_PresenceSensor.xml 6 200
D_RulesEngine1.xml 6 200
D_SceneController1.xml 6 200
D_SceneControllerLED1.xml 6 200
D_SmartSwitch1.xml 6 200
D_SmartSwitchController1.xml 6 200
D_SmokeSensor1.xml 6 200
D_SmtpNotification.xml 6 200
D_Sonos1.xml 6 200
D_SysMon.xml 6 200
D_TemperatureSensor1.xml 6 200
D_VMotion.xml 6 200
D_VSwitch.xml 6 200
D_VeraBridge.xml 6 200
D_VeraConnectWWN1.xml 6 200
D_VeraConnectWWNDeauth1.xml 6 200
D_VeraConnectWWNStructure1.xml 6 200
D_WPSwitch1.xml 6 200
D_ZWaveNetwork.xml 6 200
D_ZWay.xml 6 200
D_ZigbeeNetwork.xml 6 200
D_openLuup.xml 6 200
D_openWeather.xml 6 200
J_ALTUI_RulesEngine1.js 5 200
J_ALTUI_api.js 5 200
J_ALTUI_iphone.js 5 200
J_ALTUI_jquery.ui.touch-punch.min.js 6 200
J_ALTUI_loc_fr.js 3 200
J_ALTUI_multibox.js 6 200
J_ALTUI_plugins.js 6 200
J_ALTUI_uimgr.js 6 200
J_ALTUI_upnp.js 5 200
J_ALTUI_utils.js 5 200
J_ALTUI_verabox.js 6 200
J_DeusExMachinaII1_ALTUI.js 5 200
J_PresenceSensor_ALTUI.js 5 200
J_SmartSwitch1.js 5 200
J_SmartSwitchController1.js 5 200
css/bootstrap.css 20 200
css/sarah.png 5 200
favicon.ico 2 200
icons/DayTime_0.png 1 200
icons/DayTime_100.png 1 200
icons/Door_Lock_0.png 3 200
icons/Door_Lock_100.png 3 200
icons/MString.png 2 200
icons/PresenceSensor_0.png 1 200
icons/PresenceSensor_100.png 1 200
icons/SceneController.png 1 200
icons/Sonos_0.png 2 200
icons/Sonos_100.png 1 200
icons/Sonos_125.png 1 200
icons/Sonos_150.png 1 200
icons/Sonos_25.png 1 200
icons/Sonos_50.png 1 200
icons/Sonos_75.png 1 200
icons/SysMon.png 2 200
icons/binary_light_off.png 2 200
icons/binary_light_on.png 2 200
icons/button_home_selected.png 1 200
icons/button_night_selected.png 1 404
icons/co_sensor_tripped.png 1 200
icons/co_sensor_untripped.png 2 200
icons/dimmable_light_10.png 1 200
icons/dimmable_light_100.png 1 200
icons/dimmable_light_off.png 2 200
icons/door_lock_locked.png 1 200
icons/door_window_untripped.png 1 200
icons/garage_door_closed.png 1 200
icons/humidity_sensor_default.png 3 200
icons/iconVSwitch_0.png 2 200
icons/light_sensor_default.png 1 200
icons/meter_default.png 3 200
icons/motion_sensor_tripped.png 1 200
icons/motion_sensor_untripped.png 1 200
icons/scene_controller_default.png 2 200
icons/smoke_sensor_untripped.png 1 200
icons/temperature_sensor_default.png 2 200
icons/thermostat_mode_heating.png 1 200
icons/uv_sensor_default.png 1 200
index.html 2 200
[/code]
[code]DataWatcher CONFIGURATION at Fri May 4 20:38:52 2018
DAEMON = {
VERSION = “2016.10.10”,
client = “DataWatcher”,
destinations = {“127.0.0.1:2003”},
errors = {count = 0},
http = {received = 2},
ip = “10.99.99.21”,
start_time = “Thu May 3 21:49:01 2018”,
udp = {
last_received = {},
last_sent = {[“127.0.0.1:2003:inet”] = “HomeEnergyMonitor.summary.Amps.m 99.118 1525480685”},
received = 0,
sent = 6299
DATAWATCHER = {
VERSION = “2017.09.18”,
live_energy_usage = {},
memory_stats = {},
tally = {
HTTP_relayed = {
[“HomeEnergyMonitor.summary.Amps.m”] = 1367,
[“HomeEnergyMonitor.summary.KWH.m”] = 1362,
[“HomeEnergyMonitor.summary.Volts.m”] = 1370,
[“HomeEnergyMonitor.summary.Watts.m”] = 799,
[“NEST.Humidity.current.m”] = 2,
[“NEST.Temperature.current.m”] = 22,
[“Weather.humidity.m”] = 19,
[“Weather.temperature.m”] = 40,
[“Zone0.humidity.m”] = 18,
[“Zone0.temperature.m”] = 27,
[“Zone12.temperature.m”] = 2,
[“Zone16.humidity.m”] = 15,
[“Zone16.temperature.m”] = 28,
[“Zone26.temperature.m”] = 1,
[“Zone27.humidity.m”] = 15,
[“Zone27.temperature.m”] = 25,
[“Zone3.temperature.m”] = 1,
[“Zone32.humidity.m”] = 16,
[“Zone32.temperature.m”] = 29,
[“ZoneP.humidity.m”] = 27,
[“ZoneP.temperature.m”] = 30,
[“openLuup.cpu.m”] = 273,
[“openLuup.memory.m”] = 273,
[“veraPlus.cpu.m”] = 264,
[“veraPlus.memory.m”] = 274
UDP_relayed = {},
watched = {}
translations = {}
[cache] = {
LOCAL_DATA_DIR = “whisper/”,
UDP_RECEIVER_PORT = “2003”
[dash] = {
DATAMINE_DIR = “”,
ICON_PATH = “/cmh/skins/default/img/devices/device_states/”,
VERAS = “”
[graph] = {
DATAMINE_DIR = “”,
[mine] = {DATAMINE_DIR = “”}
[relay] = {
DESTINATIONS = “127.0.0.1:2003”,
LINE_RECEIVER_PORT = “”,
LIVE_ENERGY_USAGE = “”,
MEMORY_STATS = “”,
SYSLOG = “”
}[/code]
[code]DataCache CONFIGURATION at Fri May 4 20:39:10 2018
DAEMON = {
client = “DataCache”,
destinations = {},
ip = “10.99.99.21”,
udp = {
last_received = {[“127.0.0.1:2003”] = “HomeEnergyMonitor.summary.Amps.m 53.512 1525480745”},
last_sent = {},
received = 6303,
sent = 0
DATACACHE = {
VERSION = “2016.10.04”,
rules = {rewrites = {}},
stats = {
cpu = 0.029,
updates = 6303
tally = {
[“HomeEnergyMonitor.summary.Amps.m”] = 1368,
[“HomeEnergyMonitor.summary.KWH.m”] = 1363,
[“HomeEnergyMonitor.summary.Volts.m”] = 1371,
[“HomeEnergyMonitor.summary.Watts.m”] = 800,
n = 25,
whisper = “whisper/”
[cache] = {
[dash] = {
DATAMINE_DIR = “”,
VERAS = “”
[graph] = {
DATAMINE_DIR = “”,
[relay] = {
MEMORY_STATS = “”,
SYSLOG = “”
}[/code]
Not sure about the question of "using datayours stand alone or using it as Altui? I installed a while ago datayours and the graphite cgi plugin and I select my datasource in Grafana. This setup works 100% until this week…
