I thought I jumped my big hurdle in mounting my cifs for DY operation. And yes, it’s up as per my previous post.
But now I am doing what should be basic things to actually get DY to write something to my mount folder. This stems from the DY docs that leave me a bit confused. It would be nice to see the actual DY variable screen and where we need to add the variable in setting this all up. I have been doing what I “think” the docs are saying, but it ain’t working. I only keep getting the error on the front of the DY plugin window…“[string “-------------------------------------------…”]:94: cannot open /192.168.xxx.1/Whisper/: No such file or directory”.
At this point I have the following variable data I used…
DAEMONS Watcher, Cache, Graph, Dash
CONFIG_DIR /192.168.xxx.1/Whisper/ This is my actual nas folder location which is mounted and appears fine doing a df command
DESTINATIONS /192.168.xxx.1/Whisper/ Don’t even know what this variable is but I assume it is where DY data should be going to
LOCAL_DATA_DIR /192.168.xxx.1/Whisper/ Same as above, but what is LOCAL? My LAN, my Vera. No clue to me.
VERAS xxx.xxx.xxx.xxx:3480 This one I get.
Above is ALL I did in DY. But it’s not working. Rebooted 5 times, DY has not added any other devices to my dashboard. My folder share is mounted and inside I also have the 2 schema config files there. I can do the http dashboard request and the DY Ui is there. I can see my devices. But it will not write any aggregates to my Whisper folder. If I try, I get… Error creating: Vera-50106084.039.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped
Status messsage = [string “module (“L_DataWhisper”, package.seeall)…”]:658: Cannot create file ‘%s’
Since DY setup can’t find my Folder Whisper, I can see why I cannot create an aggregate.
I used DY on my Vera 3 and now on the VeraPlus everything seems a pain. If I actually understood what DY was needing I could figure it out. But at this point some direction would be appreciated. Spend hours trying to get this up.
