AK,
Any easy way to cleanup some no more valid graph ?
I change a bunch of variable name and still see the old one…
AK,
Not really an openLuup issue, but it’s as described in the User Guide:
[quote=“akbooer, post:2, topic:195345”]Not really an openLuup issue, but it’s as described in the User Guide:
So by renaming all my graph, I’m stuck with all the others name…
click whisper then hover over any variable and click select then clear selection and type the name of the graph you want to remove and save graph - this will remove the named graph
Thanks! Found out that deleting the files under whisper/ directory did the cleanup too
