ello
Have just installed the Data Mine 2 on my Vera3 UI7. But I do not get logging to work. It is red and is not online.
Sending with debug information desk.
-1-===========================================================================
50 01/22/17 18:59:00.569 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 18:59:00.569 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 18:59:00.570 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 18:59:00.571 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:01:08.979 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:01:08.980 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:01:08.980 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:01:08.981 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:04:28.985 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:04:28.985 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:04:28.986 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:04:28.987 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:05:20.636 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:05:20.637 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:05:20.638 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:05:20.638 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:29:30.633 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:29:30.634 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:29:30.634 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:29:30.635 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:31:18.114 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:31:18.114 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:31:18.115 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:31:18.116 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:41:40.616 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:41:40.616 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:41:40.617 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:41:40.617 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:44:31.185 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:44:31.185 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:44:31.186 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:44:31.186 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:47:40.561 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:47:40.561 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:47:40.562 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:47:40.563 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:48:04.211 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:48:04.212 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:48:04.213 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:48:04.214 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:50:40.588 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:50:40.589 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:50:40.590 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:50:40.590 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:53:40.607 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:53:40.608 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:53:40.608 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:53:40.619 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:54:46.251 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:54:46.251 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:54:46.252 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:54:46.252 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
50 01/22/17 19:56:40.623 luup_log:90: dataMine: Logging error logging variable 14:upnp-org:serviceId:TemperatureSensor1::CurrentTemperature <0x2c2d7680>
50 01/22/17 19:56:40.624 luup_log:90: dataMine: Unable to open file for write /dataMine/database/4/raw/2455.txt <0x2c2d7680>
50 01/22/17 19:56:40.625 luup_log:90: dataMine: Error: ‘/dataMine/database/4/raw/2455.txt: No such file or directory’ <0x2c2d7680>
06 01/22/17 19:56:40.625 Device_Variable::m_szValue_set device: 14 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: true now: true #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2c2d7680>
-2-===========================================================================
/dev/sdb1: LABEL=“KINGSTON” UUID=“6236-BC9F”
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock7 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/mtdblock8 on /mios type squashfs (ro,relatime)
none on /proc/bus/usb type usbfs (rw,relatime)
dev/sda1 on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
-4-===========================================================================
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sdb: 4011 MB, 4011851776 bytes
88 heads, 24 sectors/track, 3710 cylinders
Units = cylinders of 2112 * 512 = 1081344 bytes
Device Boot Start End Blocks Id System
/dev/sdb1 4 3711 3913792 b Win95 FAT32
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -6236-BC9F
SetMountPoint -dev/sda1
SetManualMount -0
-6-===========================================================================
{“Version”:“2.000”,“dbVersion”:2,“Events”:{“count”:0,“last”:0},“guiConfig”:[],“Variables”:[{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:SwitchPower1”,“AggregateBy”:0,“AggregationType”:0,“DrowsyError”:0,“LastRec”:0,“LastHistory”:1104516000,“DrowsyWarning”:0,“Type”:0,“FirstRec”:0,“LastVal”:1,“Id”:1,“FixYAxis”:0,“DataMultiplier”:1,“DataType”:3,“Device”:59,“DataOffset”:0,“Name”:“Ljusrelä Nexa - Status”,“FilterEnable”:0,“Logging”:0,“Variable”:“Status”,“historyState”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:SecuritySensor1”,“AggregateBy”:0,“LastHistory”:1104516000,“AggregationType”:0,“LastRec”:1485103850,“FilterMinimum”:0,“Device”:52,“FilterMaximum”:0,“FirstRec”:0,“Type”:0,“LastVal”:0,“DataType”:6,“Id”:2,“FixYAxis”:0,“DataMultiplier”:1,“DrowsyWarning”:0,“DrowsyError”:0,“DataOffset”:0,“Name”:“rörelse - Tripped”,“FilterEnable”:0,“Logging”:1,“Variable”:“Tripped”,“historyState”:0,“TimeOffset”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:LightSensor1”,“AggregateBy”:0,“LastHistory”:1104516000,“AggregationType”:0,“LastRec”:1485106456,“FilterMinimum”:0,“Device”:25,“FilterMaximum”:0,“FirstRec”:0,“Type”:0,“LastVal”:1,“DataType”:4,“Id”:3,“FixYAxis”:0,“DataMultiplier”:1,“DrowsyWarning”:0,“DrowsyError”:0,“DataOffset”:0,“Name”:“_Light Sensor - CurrentLevel”,“FilterEnable”:0,“Logging”:1,“Variable”:“CurrentLevel”,“historyState”:0,“TimeOffset”:0},{“Service”:“urn:upnp-org:serviceId:TemperatureSensor1”,“LastRec”:1485111400,“Type”:0,“FilterEnable”:0,“Logging”:1,“Id”:4,“FixYAxis”:0,“DataMultiplier”:1,“DataType”:1,“DataOffset”:0,“Name”:“Ute temp - CurrentTemperature”,“LastVal”:3.62,“FirstRec”:0,“Variable”:“CurrentTemperature”,“Device”:14},{“Service”:“urn:upnp-org:serviceId:TemperatureSensor1”,“AggregateBy”:0,“AggregationType”:0,“LastRec”:0,“TimeOffset”:0,“FixYAxis”:0,“FilterMaximum”:0,“DrowsyWarning”:0,“Type”:0,“FilterEnable”:0,“Logging”:1,“Id”:5,“FilterMinimum”:0,“DataMultiplier”:1,“DataType”:1,“DrowsyError”:0,“DataOffset”:0,“Name”:“Temp V-rum - CurrentTemperature”,“LastVal”:0,“FirstRec”:0,“Variable”:“CurrentTemperature”,“Device”:15}],“Graphs”:[],“LastWrite”:1484774129,“nextId”:6}
-7-===========================================================================
