I am using datamine to record my light on/off status, which it is doing nicely.
My question is how can I display a graph of say 10 lights on the same graph where they are not superimposed on each other? I need to stack up the lights row by row to compare their on/off times to each other.
Then I can use the graph to tweak my light programs better.
Just guessing but you could probably add a different “Data offset” to each channel to get the layout you want - look at the variable’s/channel’s properties in the config.
