Hi
Please can someone let me know if I should have a dataMine directory on Vera?
root@MiOS_12345678:/# ls bin etc mios overlay rom sbin tmp var dev lib mnt proc root sys usr www
If I do, what should be in it?
Many thanks…
Hi
Many thanks…
Look in /www
Yes - in the root directory there should be a “dataMine” directory - under that directory is datamine’s saved data on the USB stick. Under the “www” there should be a “dm” directory. I just updated my firmware to 1.5.622 and it kindly removed the “dataMine” directory but fortunately not the contents of the USB stick itself. Recreating the “dataMine” directory with WinSCP restored all the lost functionality after a couple of restarts.
Thanks guys, so what exactly should be in that directory? I’ve tried to remove and reinstall dataMine but that directory does not get recreated?
Best to continue this with Chris in the dataMine thread - however under the dataMine directory are all the directories the program automatically creates. If you don’t have any then that’s a problem - possibly with the USB stick mounting. Check datamine’s own log page.
@A-lurker please could you share what’s in yours from the command line -# ls
I appreciate it will be slightly different but it’ll help me get a feel of what’s needed.
@Chris seems to be working on other things now, so self and community support is required at the moment…
From root:
bin
dataMine
dev
etc
lib
mios
mnt
overlay
proc
rom
root
sbin
sys
tmp
usr
var
www
Then in the dataMine directory - and that all this stuff is located on the USB stick:
History <-- this directory is empty in my set up
Notifications [R2280].txt <-- one for every week recorded
dataMineConfig.json <-- config file
dataMineConfig.json.Fri Sep 13 18-30-15 2013.backup <-- there can be a few of these
database <-- the directory that contains all the recorded data
sunriseSunset.txt <-- holds all the sun set/rise times
Then in the “database” directory - there are numbered directories - one for each channel (ie the Vera variables) being recorded. Every one of these then has the subdirectory: “raw”. There are no files under the channel numbered directories - just the “raw” directory.
/dataMine/database$ ls
1
2 <-- no files under here or any of the other channel directories - only a "raw" subdirectory is to be found
3
4
5
6
7
8
9
Here is the data stored in the /dataMine/database/xvy/raw" directory. Each file is a week worths of data. The file name is the numbers of weeks since the UNIX epoch.
/dataMine/database/1/raw$ ls
2242.txt
2243.txt
2244.txt
2245.txt
2246.txt
2247.txt
2248.txt
2249.txt
2250.txt
2251.txt
2252.txt
2253.txt
2254.txt
2255.txt
2256.txt
2257.txt
2258.txt
2259.txt
2260.txt
2261.txt
2262.txt
2263.txt
2264.txt
2265.txt
2266.txt
2267.txt
2268.txt
2269.txt
2270.txt
2271.txt
2272.txt
2273.txt
2274.txt
2275.txt
2276.txt
2277.txt
2278.txt
2279.txt
2280.txt
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
