Hi, does anyone know what this logging means? I’m wondering if they are maybe old device numbers where Vera increments if a device is deleted and re-added as we know the device ID doesn’t retain.
It is correct the file isn’t there either.
Should I format the USB? Maybe corruption or something?
luup_log:211: dataMine: Channel: 12 (Id:12), Start: Thu Aug 9 19:47:43 2018, Stop: Fri Aug 10 19:47:43 2018, AggregateBy: 0, AggregationType: 0 <0x576bf520>
luup_log:211: dataMine: 1:Unable to open file for read - /dataMine/database/12/raw/2536.txt <0x576bf520>
luup_log:211: dataMine: 2:Finished reading files - no more data available/dataMine/database/12/raw/2535.txt <0x576bf520>
luup_log:211: dataMine: rawData points 101 <0x576bf520>
luup_log:211: dataMine: Alpha = 144 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 144 <0x576bf520>
luup_log:211: dataMine: Alpha = 18 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 18 <0x576bf520>
luup_log:211: dataMine: Alpha = 180 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 180 <0x576bf520>
luup_log:211: dataMine: Alpha = 173 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 173 <0x576bf520>
luup_log:211: dataMine: Alpha = 160 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 160 <0x576bf520>
luup_log:211: dataMine: Alpha = 201 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 201 <0x576bf520>
luup_log:211: dataMine: Alpha = 4 <0x576bf520>
luup_log:211: dataMine: Alpha lookup failed = 4 <0x576bf520>
luup_log:211: dataMine: Alpha = 133 <0x576bf520>
