There is a link in the post by @MNB, try it!
I’ve been through all of the manuals for installation and have gone through the manual installation steps and always end up at the same point (whether using [veraip]/dm or [veraip]/dmgui). The page begins to load and then ends up with an error “Unable to download channel configuration data from dataMine”. Any ideas what the issue may be?
So I finally installed DataMine 2 I think I am running the newest version (2.0). But I can’t find where to use Columns for the diagrams. I want to display rainfall/day. The only graph type I can use is: Spline, line, scatter, area or area/line. What am I doing wrong ConstantSphere?
Having issues with Datamine2 not seeing a USB. Have following instructions (I have enabled logs then disabled and only have one usb in the device) this is my debug page…
-1-===========================================================================
09 10/11/17 13:53:12.844 JobHandler_LuaUPnP::Run device 151 dataMine 2 graphing and logging plugin room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0xc58630 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x7717f000>
09 10/11/17 13:53:36.867 JobHandler_LuaUPnP::Run device 151 dataMine 2 graphing and logging plugin room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0xe6a630 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x77035000>
50 10/11/17 13:53:50.690 luup_log:151: dataMine: Initialising dataMine System (2.000) <0x76819520>
06 10/11/17 13:53:50.691 Device_Variable::m_szValue_set device: 151 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: false #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76819520>
06 10/11/17 13:53:50.692 Device_Variable::m_szValue_set device: 151 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x1066830/NONE duplicate:1 <0x76819520>
06 10/11/17 13:53:50.692 Device_Variable::m_szValue_set device: 151 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76819520>
50 10/11/17 13:53:50.707 luup_log:151: dataMine: ERROR: Startup state is ‘uninitialised’! <0x76819520>
06 10/11/17 13:53:50.707 Device_Variable::m_szValue_set device: 151 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x1066830/NONE duplicate:1 <0x76819520>
06 10/11/17 13:53:50.708 Device_Variable::m_szValue_set device: 151 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76819520>
50 10/11/17 13:53:50.708 luup_log:151: dataMine: Reinitialising configuration structure <0x76819520>
50 10/11/17 13:53:50.709 luup_log:151: dataMine: Startup complete <0x76819520>
50 10/11/17 13:54:05.184 luup_log:151: dataMine: Delete backups complete - No files found <0x74419520>
50 10/11/17 13:54:05.206 luup_log:151: dataMine: Error reading tmpfile during spacecheck <0x74419520>
09 10/11/17 14:01:17.162 JobHandler_LuaUPnP::Run device 157 dataMine 2 graphing and logging plugin room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0x984590 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x77fa3000>
50 10/11/17 14:01:28.784 luup_log:157: dataMine: Initialising dataMine System (2.000) <0x77787520>
06 10/11/17 14:01:28.785 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: EMPTY now: false #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.785 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetDataDirectorye[0m was: EMPTY now: /dataMine/ #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.786 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountUUIDe[0m was: EMPTY now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.787 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountPointe[0m was: EMPTY now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.788 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetMountOptionse[0m was: EMPTY now: #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.788 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetManualMounte[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.789 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetTimeoutPeriode[0m was: EMPTY now: 12 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.790 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetHistoryEnablee[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.791 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetUseBackupe[0m was: EMPTY now: 1 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.791 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mSetEventsEnablee[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.792 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xbb6a48/NONE duplicate:0 <0x77787520>
06 10/11/17 14:01:28.793 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: EMPTY now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77787520>
50 10/11/17 14:01:28.801 luup_log:157: dataMine: ERROR: Startup state is ‘uninitialised’! <0x77787520>
06 10/11/17 14:01:28.801 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xbb6a48/NONE duplicate:1 <0x77787520>
06 10/11/17 14:01:28.802 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77787520>
50 10/11/17 14:01:28.802 luup_log:157: dataMine: Reinitialising configuration structure <0x77787520>
50 10/11/17 14:01:28.803 luup_log:157: dataMine: Startup complete <0x77787520>
50 10/11/17 14:01:43.278 luup_log:157: dataMine: Delete backups complete - No files found <0x75187520>
50 10/11/17 14:01:43.299 luup_log:157: dataMine: Error reading tmpfile during spacecheck <0x75187520>
02 10/11/17 14:02:15.118 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download D_DataMine2.jsone[0m <0x77942000>
02 10/11/17 14:02:15.119 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set D_DataMine2.jsone[0m <0x77942000>
02 10/11/17 14:02:15.119 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download D_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.120 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set D_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.121 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download I_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.121 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set I_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.122 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download L_DataMine2.luae[0m <0x77942000>
02 10/11/17 14:02:15.122 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set L_DataMine2.luae[0m <0x77942000>
02 10/11/17 14:02:15.123 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download S_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.123 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set S_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.124 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download /…/…/www/dm/dataMine2Web.tar.gze[0m <0x77942000>
02 10/11/17 14:02:15.125 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /…/…/www/dm/dataMine2Web.tar.gze[0m <0x77942000>
02 10/11/17 14:02:15.128 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download D_DataMine2_UI7.jsone[0m <0x77942000>
02 10/11/17 14:02:15.128 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set D_DataMine2_UI7.jsone[0m <0x77942000>
02 10/11/17 14:02:15.129 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download J_DataMine2.jse[0m <0x77942000>
02 10/11/17 14:02:15.130 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set J_DataMine2.jse[0m <0x77942000>
02 10/11/17 14:02:15.131 e[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download J_DataMine2_UI7.jse[0m <0x77942000>
02 10/11/17 14:02:15.131 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set J_DataMine2_UI7.jse[0m <0x77942000>
01 10/11/17 14:02:15.239 e[31;1mDevice_LuaUPnP::LoadDeviceDoc can’t load /etc/cmh-lu//D_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.239 e[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_DataMine2.xmle[0m <0x77942000>
02 10/11/17 14:02:15.240 e[33;1mJobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 157/D_DataMine2.xml so device 157 is offline while waiting for download the filee[0m <0x77942000>
02 10/11/17 14:02:16.063 e[33;1mDevice_Service::MatchupUpnpServices no upnp service for urn:cd-jackson-com:serviceId:DataMine1e[0m <0x77942000>
01 10/11/17 14:02:21.078 e[31;1mJobHandler_LuaUPnP::CreateLuaInterfaces can’t load plugin /etc/cmh-lu//L_DataMine2.luae[0m <0x77942000>
09 10/11/17 14:02:21.690 JobHandler_LuaUPnP::Run device 157 dataMine 2 graphing and logging plugin room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0xba61b0 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x77942000>
03 10/11/17 14:02:21.722 JobHandler_LuaUPnP::Run ready 55 devices oem:1 skin:1-mios installation 45202835 missing /etc/cmh-lu//D_DataMine2.xml version 1.7.3231 allow_evt: 1 allow_ud: 1 upnp 1 netpnp: 1 reprovision: 0 secure: 0 tz:-36000 tnow:1507690941 dst: 1 gmt:39600 tz:EST / EST fahr:0 changed: 0 pMem 0x1460000 start 10260480 diff: 11104256 <0x77942000>
09 10/11/17 14:02:54.662 JobHandler_LuaUPnP::Run device 157 dataMine 2 graphing and logging plugin room 0 type urn:schemas-cd-jackson-com:device:DataMine:1 cat 0:-1 id parent 0/0x906be8 upnp: 0 plugin:8526 pnp:0 mac: ip: <0x77174000>
50 10/11/17 14:03:07.393 luup_log:157: dataMine: Initialising dataMine System (2.000) <0x76959520>
06 10/11/17 14:03:07.393 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1merrorStatuse[0m was: false now: false #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76959520>
06 10/11/17 14:03:07.394 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xb239e0/NONE duplicate:1 <0x76959520>
06 10/11/17 14:03:07.395 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76959520>
50 10/11/17 14:03:07.395 luup_log:157: dataMine: Installing update of dataMine web application <0x76959520>
50 10/11/17 14:03:34.167 luup_log:157: dataMine: ERROR: Startup state is ‘uninitialised’! <0x76959520>
06 10/11/17 14:03:34.167 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xb239e0/NONE duplicate:1 <0x76959520>
06 10/11/17 14:03:34.168 Device_Variable::m_szValue_set device: 157 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76959520>
50 10/11/17 14:03:34.168 luup_log:157: dataMine: Reinitialising configuration structure <0x76959520>
50 10/11/17 14:03:34.169 luup_log:157: dataMine: Startup complete <0x76959520>
50 10/11/17 14:03:49.251 luup_log:157: dataMine: Delete backups complete - No files found <0x74359520>
50 10/11/17 14:03:49.280 luup_log:157: dataMine: Error reading tmpfile during spacecheck <0x74359520>
-2-===========================================================================
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
/dev/mtdblock6 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
/dev/mtdblock10 on /storage type jffs2 (rw,relatime)
/dev/mtdblock10 on /etc/cmh-firmware type jffs2 (rw,relatime)
/dev/mtdblock10 on /etc/cmh-backup type jffs2 (rw,relatime)
/dev/mtdblock9 on /mios type squashfs (ro,relatime)
-4-===========================================================================
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -
SetMountPoint -
SetManualMount -0
-6-===========================================================================
{“dbVersion”:2,“Events”:{“count”:0,“last”:0},“Version”:“2.000”,“Variables”:[],“Graphs”:[],“guiConfig”:[],“nextId”:1}
-7-===========================================================================
Fixed this by removing USB from Vera, can?t explain why this solved my problem, but I?m happy and watching my rain-columns
Hello,
I have an issue with Datamine 2.0: I’ve installed it and configured couple of days ago (I’ve used the way where the data is stored on the same USB stick as the original Vera logs),
It worked fine for couple of days but today when I opened the panel (I use mostly remote connection via AltUI, if that matters) it looked like the plugin was reset.
Any variables I’ve configured to be watched for, any graphs I save, everything is gone.
Is there a way to handle that somehow? I’ll probably have to accept that I’ve lost all historical data, but what to do about this to prevent such things in future?
Or is there any option to do a backup (remotely, at best?)
Hi
How can the scale range on the Dashboard dial be changed. I need to increase it quite a bit for my application?
Thanks, Thomasx
Question on Cycle Times. My thermostats output a ModeState of ?Idle?, ?Cooling? and ?Heating?. I have a lookup table that changes Idle = 0 and Heating and Cooling =1. This works fine but Is there away to set up one for Cooling and one for Heating? I thought cloning would work but you can?t edit the clone. Any ideas?
FIRMWARE UPDATE :there’s not enough space
Not enough space to upgrade firmware, you can free more space by deleting files from the table below.
I don’t want to lost my configuration and data and I readed also this:
“NOTE: THE DATAMINE AND DATAMINE 2 PLUGIN IS KNOWN TO BE STORING DATA IN A NON-DEFAULT LOCATION ON THE CONTROLLER AND THE DATA WILL BE LOST. PLEASE DO NOT FOLLOW THIS PROCEDURE IF YOU ARE RELYING ON THESE PLUGINS.”
so i want to ask if there is a simply procedure to update my controller without to delete datamine files. Itook so a lot time to have it working and i need data I stored.
i have VERALITE, the green controller. UI7
thanks in advance.
You can Vera safely have the files deleted. It are the GUI files it deletes, not your configuration or data files. You can even have it make a backup to your local PC before having them removed. After the Vera upgrade is completed, the DataMine GUI files will be reinstalled. I have done this several times without problems.
Cheers Rene
Maybe that this app is dead, but looking to start logging temperature data now I have SSD
Whenever I set Enable for logging to true and press save, then go to another sensor, when I come back to the original Enable for logging is set back to false.
An ideas?
Cheers
C
Check the debug page and see if there are errors and your USB or SSD mount is correctly recognized in datamine. Also check to see if you have your uuid set.
Sent from my VS995 using Tapatalk
[quote=“tomtcom, post:252, topic:190421”]Check the debug page and see if there are errors and your USB or SSD mount is correctly recognized in datamine. Also check to see if you have your uuid set.
Sent from my VS995 using Tapatalk[/quote]
Thanks Tom. I did wonder about that. Debug is huge so I’ll have a search. I followed the instructions for manually setting the USB as I have extrooted and am using an SSD and uuid = NA
Cheers
C
