Dashboard as Default view
I was thinking that after the Vera is setup it was supposed to default to the dashboard view upon login. Is that the case? If so, it isn’t working that way for me… if not, I would like to at least see that as an option.
Did you create rooms and set your location? afaik, that’s what is checked to see if it’s setup or not.
Yes rooms and location are populated, but I always get the Intro page everytime.
It’s a bug, changed to go to dashboard after the rooms are set.
