With my Danfos devices I noticed following odd behaviour by using dashboard arrows to change temperature.
By LUA script / UI7 temperature change, temperatures on dashboard are changed only at point 3).
- dashboard shows 21 → 21
- UI7 shows 21
Variable
AllSetpoints
21.000000,0.000000,0.000000
AssociationNum
0
BatteryDate
04/10/2016 ? 19:12:08
BatteryLevel
89
Capabilities
81,140,0,4,8,4,R,RS,|67,70,114,117,128,129,132:2,134,143,
Commands
heater_setpoint
Configured
1
ConfiguredWakeupInterval
900
ConsecutivePollFails
0
CurrentSetpoint
21.00
CurrentSetpoint
21.00
FirstConfigured
25/09/2016 ? 09:10:48
LastArr
1475584536,13
LastNnu
1475582790,13
LastPollSuccess
04/10/2016 ? 19:25:42
LastReset
0
LastRouteUpdate
25/09/2016 ? 09:11:48
LastUpdate
LastWakeup
ManufacturerInfo
2,5,3
ModeSetting
1:;2:;3:;4:
ModeStatus
HeatOn
Neighbors
1,2,5,6,11,12,13,15,16,17,
NodeInfo
43,46,72,75,80,81,84,86,8f,
PollOk
5
PollRatings
5.00
SetPointInfo
H1,
SetpointTarget
21
Status
0
Target
0
TemperatureScale
2,0,2
VersionInfo
6,2,67,2,51
WakeupInterval
900
WakeupRatings
2.50
- Modification of dashboard target by using down arrow it shows 21 → 22
- UI7 shows 21 + waiting for wakeup to send command
- After device wakeup, UI7 shows 22
- top of dashboard change of color indicating transmission but dashboard still shows 21-> 22
- If you select another room and come back to initial room then dashboard shows 21 → 21
Variable
AllSetpoints
AssociationNum
0
BatteryDate
04/10/2016 ? 19:41:15
BatteryLevel
86
Capabilities
Commands
heater_setpoint
Configured
1
900
0
CurrentSetpoint
22
CurrentSetpoint
21.00
FirstConfigured
LastArr
1475584536,13
LastNnu
1475582790,13
LastPollSuccess
LastReset
0
LastRouteUpdate
LastUpdate
LastWakeup
ManufacturerInfo
2,5,3
ModeSetting
1:;2:;3:;4:
ModeStatus
HeatOn
Neighbors
NodeInfo
PollOk
5
PollRatings
5.00
SetPointInfo
H1,
SetpointTarget
22
Status
0
Target
0
TemperatureScale
2,0,2
VersionInfo
6,2,67,2,51
WakeupInterval
900
WakeupRatings
2.50
- if you look at the device it shows 22
- dashboard still shows 21 → 21
- if you select another room and come back to initial room then at last dashboard shows 22 → 22
Variable
AllSetpoints
22.000000,0.000000,0.000000
AssociationNum
0
BatteryDate
BatteryLevel
86
Capabilities
Commands
heater_setpoint
Configured
1
900
0
CurrentSetpoint
22.00
CurrentSetpoint
22.00
FirstConfigured
LastArr
1475584536,13
LastNnu
1475582790,13
LastPollSuccess
04/10/2016 ? 19:45:07
LastReset
0
LastRouteUpdate
LastUpdate
LastWakeup
ManufacturerInfo
2,5,3
ModeSetting
1:;2:;3:;4:
ModeStatus
HeatOn
Neighbors
NodeInfo
PollOk
5
PollRatings
5.00
SetPointInfo
H1,
SetpointTarget
22
Status
0
Target
0
TemperatureScale
2,0,2
VersionInfo
6,2,67,2,51
WakeupInterval
900
WakeupRatings
2.50
AltUI v1.65.1851
VeraPlus lastest firmware v1.7.2138
