Danalock?
I was one of the original backers of Lockitron, but after a full year waiting finally gave up once they announced their new “Bolt” product that requires a full replacement of the lock. Did a little bit of research, was considering the August since they have that new “Connect” add-on, but since it wasn’t available yet I went with the Danalock - the Circle with both Zwave and bluetooth. Ordered it on Wednesday and it was actually at my doorstep by noon on Friday … pretty impressive given it came from Denmark and I’m in Toronto. Import fees were steep unfortunately - added about $40 to the total - but nothing to do with the company.
So today I set aside the afternoon, thinking I’d probably need most of it to get it installed an configured. I was totally wrong. There was minimal instructions included, but there was a sheet that directs you them on the web - a little poorly worded, but relatively easy to follow. It literally took me no more than 15 minutes to get the thing mounted on my door - if that. Maybe I was lucky, but it was simply a matter of removing my old lock’s baseplate and replacing it with the one provided with the Danalock. The existing screws fit the template, and I didn’t even have to use the “tailpiece” included as mine fit fine.
Once it was installed I wanted to test it manually - it’s a little counter-intuitive as you turn it the opposite way from what you’d expect, but no big deal. Also a little stiff to start. Then moved on to the button, one push to lock, a longer push to unlock. Seemed to have a problem to start where it wasn’t fully unlocking, but after a couple of cycles (manual and via the button) it seemed to adjust. But of course I didn’t buy this to use it manually, I wanted to check out the pairing.
First up was the phone. Downloaded the app, followed the instructions to put it in inclusion mode, and had it paired in less than a minute - on the first go-around. It’s a fairly simple app, but easy enough to lock and unlock it from there. There’s a slight delay when hitting the button before you hear/see the lock respond, but it’s only about 2-3 seconds.
Then of course what I figured would be the challenge - getting in included in my Vera system. As you probably have found, getting new devices paired properly can sometimes be a challenge. The Danalock was included on the 2nd go - I’m not sure if the instructions on the Danalock website are correct, it says to hit the button twice for Zwave, and three times for Bluetooth. It seemed (and I might be wrong) that I had to do three times to get it recognized. Regardless it was way less painful than I’ve had with other devices. It was recognized and setup as a lock as it should. As far as controlling via Zwave, it’s working ok at the moment - the delay seems a little longer, but can’t say for sure if it’s the lock or the Vera. I’m going to try to do a repair to see if that helps.
I haven’t tried all the features yet, but from the basics of having a Bluetooth/ZWave enabled lock I’m pretty pleased!
