Great! If you feel like it, you could retry with the Generic camera plug-in. That’s how I have it running with your camera. I did install it from scratch, as I only had the Panasonic one installed.
@Henk
Now that it is working, I would edit the previous posts and remove/obfuscate the domain names, port numbers and other stuff that is specific and not relevant.
Url /image/jpeg.cgi
Username admin
Password xxxxxx
MAC 00265A08F0FA – THIS IS THE # ON THE BACK OF THE CAMERA, NOT SURE IF THAT’S WHAT I NEED
IP 192.168.81.211
[quote=“Dana_CMGI, post:24, topic:167509”]I have the following:
Url /image/jpeg.cgi
Username admin
Password xxxxxx
IP 192.168.81.211
I still get “Trying to get image from camera”
Let me know what else to try.[/quote]
If yours is a D-Link like @aschwalb, you could try these;
Let’s try a few things on your DCS-920. Change one thing at a time, and then re-test, so we know what, if anything made the difference.
This is exactly what I’ve got (but check there are no spaces at the end of the text).
Username admin
Password xxxxxx
This differs from what I use (I have added a user on the camera’s web management at Maintenance > Device Management > Add User Account), but I tested it with the admin password and it seems to work.
MiOS isn’t good at correctly escaping HTML-special characters, so if your password has non-alphanumeric characters, it might be sending the password wrong. Set your password to just alphanumeric characters while you do your testing.
I have the MAC address field set to empty. I don’t see how it could be interfering, but blank it out just in case.
Try displaying the image using a web browser on your computer: http://192.168.81.211/image/jpeg.cgi — does this (prompt for your admin user/pass and) display the image?
On the camera’s web management page (Maintenance > Device Settings), I have User Access Control = Enable; Snapshot URL Authentication = Enable. See if changing those settings one at a time makes any difference.
From the questions you are asking, you look like you think that my cameras are accessible from outside my LAN, over the Internet. They aren’t. My D-Link cameras are only visible on the LAN. If the 942 has Internet-enabled features then it isn’t anything I know about.
DDNS and Port Forwarding allow access from your camera on the internet.
DDNS helps you find your house. A Hacker does not need this. But Port Forwarding opens up a hole in your router. The problem with that is it’s trivial for hackers to find your device with Port Scanners.
In the US, I regularly see someone port scanning my IP looking for vulnerabilities.
Once they get past your router … it’s very easy to get at anything behind it.
IP Cameras, Your Router, (as does Vera) have a mini Unix Kernel. Many of these devices have default passwords or their default password is tied to their MAC ID which is visible to an Internet Hacker. From any of these Unix enabled device they can launch, or be controlled as part of coordinated attack on someone else. At that time all of the evidence points back to you!
What I am trying to tell you is that if you use anything less than an SSH or VPN tunnel to allow access to a device Inside your Home from Outside your house it’s like leaving your house door open with a sign outside that says free money, drugs, and bullets.
If you do not know what SSH or VPN mean … than you should definitely not be doing any of this!
I know what you mean. I had been able to set this up jus changing the default 80 port to another. Everything is now working perfect. Thanks anyway for your help.
