Anyone esperience with the dcs-932L camera from d-link. trying to set it up since 2 days. Test no picture.
Make sure to use the right streaming URL. If you’ve manually added the camera then try to use this URL: image/jpeg.cgi
Add it in the Settings of the camera under Advanced → Extra Parameters → Variables → URL
If this URL doesn’t work then access the camera locally and check the snapshot URL and use that one.
The D-Link DCS-932L should work with Vera since it supports the MJPEG compression format.
