Hey Guys,
I was using D_HVAC_ZoneThermostat1 to create a device to enter a desired temperature. I used PLEG to compare the desired temp against the temp reported by an everspring st814 to turn on or off the furnace.
With one of the updates to UI17, the D_HVAC_ZoneThermostat1 stopped working. If you try and enter a temperature, a quick message about ‘command failed’ flashes, and the temp resets to 0.
Anybody know what changed, or how I can debug this?
Thanks,
Jim
