How can I repeat actions when conditions are triggered?
Sorry, not enough information here to give you an answer. Detail?
For example, repeat:on,off,on,off…
you have to simply in the “Activities” tab add this manually. There is no “function” like “repeat for 5” times or something.
So add
Device Action, then the device/lamp/whatever and then select “common actions” “Turn On or Off” and alternate with “0” (=Turn Off) and “1” (=Turn On)
You can also use the “SetTarget” and use again “0” (Off) and “1” (On) and sequentially list them for as long as you want this to take place.
