With an eye toward monitoring my air conditioner I’d like to log its on/off cycles, possibly with something like the datamine logger.
I would like to know if the Honeywell YTH8320ZW1007 Z-Wave Thermostat reports to Vera each time it cycles on or off, or if it must be polled to determine its current state.
If it must be polled, I will probably not choose it. In which case the question changes to; is there a better option than a Door/Window sensor attached to a relay to tell Vera when the air handler goes on and off?
Thermostat Operating State
The thermostat can send the message containing the actual state of the HVAC equipment
based on equipment state change.
The thermostat provides the following operating states:
? Idle - no equipment on
? Heating - heating equipment on
? Cooling - cooling equipment on
? Pending Heat - minimum off time applied to protect the heat pump compressor
? Pending Cool - minimum off time applied to protect the heat pump compressor
I am able to do this with the Trane Thermostat that I have. (See attached screenshot)
No problem glad to help. I have my Trane set with a 2 degree “Deadband” or delta so if it’s set to 75 F it doesn’t start cooling until it reaches 77 F and doesn’t shut back off until 75 F. By default it’s set to a 1 degree delta and I found it would cycle the A/C on and off too much. Not sure if the Honeywell is set that way or not, might be something to check. I only wish I could easily export the datamine data to a CSV.
Ya I tried to use the CSV from datamine, but it’s a pain. Unix timestamp that you can convert in Excel, the real problem is it creates multiple CSV file for each datapoint. Or maybe there is something wrong with my datamine have you been able to use the CSV or txt that it creates?
