Customize Wireless Tag System to Vera3
I am looking at an application using My Vera3 system and the Wireless Tags from Cao Gadgets, LLC for the ability to detect presence. The Wireless Tag System works relatively well in my home. I have tried to contact the people at Cao Gadgets but get no response. For those programmer/technical types (I tried PM’ing a couple of you but got no response) here is the scenario.
The Wireless Tag Software Application allows for the ability to set a “range”, upper and lower values on a slider bar under Temperature to “alarm” when the temperature goes outside of the defined range. I tried it, it works. Also, using the URL call I would like to trigger a "Scene"on my Vera3.
What I am trying to accomplish is a similar “alarm” based upon “Signal Strength” (pic3). This value is displayed per each “Tag” when the Ping/Polling is performed (e.g. Signal: -15dBm). I am able to determine that there is a correlation between “distance from the TAG MANAGER and the SIGNAL VALUE”. The dBm value is being returned to the APP and my thought is to somehow provide the capability to implement a similar event, identical to the TEMPERATURE ALARM EVENT. This would, IMHO, provide a potential solution for my needs. I would like to be able to detect when a tag gets within a defined distance “TO” (pic1 : e.g -15dB or <5’) or “FROM” (pic2 : e.g. -35dB >20’) the Tag Manager or in a GRID implementation from a Mesh of Tag Managers. I realize there would be differences in TAG dBm values, but dBm should be unique to a defined TAG. Anyway, I have two Tag Managers and 5 Tags and am ready to find a Solution, Test and provide any Results and/or Experiences with the community.
Just looking for ideas, thoughts and hopefully a solution.
Thanks for any input.
MWP
What this has to do with Vera, I don’t know.
I would expect a scheme such as you are trying to implement, based on signal strength, would be highly unreliable. I also see no way of implementing such a scheme without directly modifying teh tag monitor’s software.
But the system you indicate already has presence notification built in. Why don’t you just use that?
Hey Z-Waver
1st -If your’e a Site Administrator…take my post down.
2nd -Integrating overall to my Vera system.
"Also, using the URL call I would like to trigger a “Scene"on my Vera3”
3rd -I have the Tag Manager implemented and I am confident in the Signal dBm after testing.
4th -If you have the Tag System and understand how it works you would understand what I am trying to accomplish.
Thanks for your input.
MWP
According to their Documentation URI calling is supported for “When lost link to tag” If you can set the dbm vaules that the tag needs to show it is connected this is a start. The only issue is the physical obstructions between the tags and ethernet base unit is going to greatly affect the receive levels. If you are always approaching the base unit with a tag it may require a liitle trial and error. I think the idea of signal strength reporting is to tell you about whether the device is there and reliable working or not. IMHO don’t think is was ever designed to be used as a distance calculator. Have fun. Lets us know if it works out.
@spudjr
Yes, the “out-of range” and “in-range” notification" URL calls work as tested. The more granular approach that I am looking for is to be able to identify/alert when a Tag is within, let’s say 1’ to 15’ or 50’ to 75’ of the “Tag Manager” base station. I concur with your opinion that that the dBm value/reading was designed to show signal strength, instead of a rudimentary distance calculator. My “thought/idea” is to possibly leverage that the Tag Manager and Tag are already providing a piece of data (dBm Signal) that could “possibly” be used as a distance identifier. My reasons or purpose for this exercise is to identify and “alert/trigger” via Vera when a Tag moves within a “defined controlled” area (distance) to an installed Tag Manager. This whole exercise is very specific and will definitely be “Tested” (e.g. trial and error) for each Tag. I also have realized that each Tag has variability in their respective dBm signals. But I also see a “somewhat linear” relationship within each Tag. If successful, I will then try a “Grid” approach using multiple Tag Managers…Keep pushing the boundaries.
The Temperature alert configuration struck me as being a straight-forward way to defining the “range WITHIN a in/out of range boundary” alert rule. My interest in not only know when a Tag is “in-range” or “out-of-range” but to identify the Tag “within-the-range”. I would also like the ability of a URL call to apply to this alert configuration.
I will take your advice and “Have Fun” as I believe so many others on this site experience the Fun, albeit sometimes frustration, of this type of technology. After all, you read this site and see many other people stretching and breaking the boundaries of all these devices, plugins, interfaces, etc.
Will definitely post any successes, or inabilities, to provide solutions.
MWP
