[quote=“geniepro, post:11, topic:189769”]I have the zwave version, YTH8320ZW1007.
The TStat does report the set points, since the “AllSetpoints” variable is updated correctly, but the CurrentSetpoint Cool/Heat are not updated.[/quote]
I have the same unit and have the same problems with my Edge UI7. On my older Vera 3 still using UI5 I think it has a much better dashboard display. With UI7 I have to do the same as geniepro, select the mode then change the set point. So what I did was to set up a few scenes and change the set points with LuuP code. Here is an example for home and away settings. I have 4 Honeywell thermostats in two different locations and two Veras that are bridged.
[code]Home
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “76”},170)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “76”},171)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “78”},216)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “78”},214)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “65”},170)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “60”},171)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “65”},216)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “65”},214)
luup.call_action(“urn:micasaverde-com:serviceId:HaDevice1”, “Poll”, {}, 170)
luup.call_action(“urn:micasaverde-com:serviceId:HaDevice1”, “Poll”, {}, 171)
luup.call_action(“urn:micasaverde-com:serviceId:HaDevice1”, “Poll”, {}, 216)
luup.call_action(“urn:micasaverde-com:serviceId:HaDevice1”, “Poll”, {}, 214)
Away
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “85”},170)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “78”},171)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “85”},216)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“SetCurrentSetpoint”,{NewCurrentSetpoint = “85”},214)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “55”},170)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “55”},171)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “55”},216)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“SetCurrentSetpoint”, {NewCurrentSetpoint = “55”},214)
[/code]
