Veralite Firmware 1.6.641
2gig CT100 Z-Wave Programmable Thermostat
Hey y’all. I think there is something wrong with either my CT100 or Vera. I added the 2gig CT100 and have been using it for about 2 months. I just realized, there is a setting missing in the Vera interface. I only see one temperature setting where there should be two. I see only the red temp setting and the blue one is missing. I would assume there should be two for the Auto mode setting. This way the thermostat will change between heat and cool based on the temperature. Since there is only one temperature setting, it renders Auto useless. I have attached a screenshot. Anyone else have this issue. Any known fix?
Runout74
