CT100 Batteries Replaced, how to refresh battery status?
As the title says, batteries were getting low on the thermostat so I replaced them with fresh ones. Vera still shows the battery levels as they were pre-replacement. So how do I get vera to recognize that I put fresh batteries in?
Currently vera is reporting a battery level of 7% in settings-advanced and showing the low battery icon on the dashboard. This is incorrect as I put fresh batteries in. I’ve tried reconfiguring the device, polling the device, going to settings-advanced and deleting the value in both battery level and battery timestamp then reloading, I have also restarted vera. No dice. Advice?
There is a reset button behind the top panel on the stat. I have had luck with pushing it and getting the battery to update.
Knew it was probably something simple. I don’t have the manual, do you have to repair zwave after resetting?
Nope it’s just a the thermostat not the settings.
