Just FYI…
Heads up, home automation fanatics: It seems that the CEDIA folks have got the inside scoop on Crestron’s new Prodigy Home Control System – and have been kind enough to share their hard won knowledge with us. A lower-cost system aimed at the mass market, this guy features a ZigBee-compatible controller with remote, a SideShow-combatible in-wall touch panel for all of your fave widgets, and the usual control switches, dimmers, and thermostats. The system starts at around $825 for the PMC2 controller (up to 100 wireless devices), PLX2 remote, and P-MNETGW wireless gateway. Or you can just bite the bullet and go for the sample system which includes the above, four zones of audio, one thermostat, 15 wireless light dimmers/switches, and the in-wall touchscreen for about $5,500. Or, if none of the above appeal to you, you can just turn off your own lights. Be sure to check out those glamor shots in the gallery below.
