Creating virtual garage opener/closer
All,
I am trying to create myself a virtual garage door operator device.
I am going to use a fibaro door/window sensor (to sense the current state of the door) and a fibaro dimmer to activate the switch (that controls the garage door) remotely.
So far I have successfully created a scene which turns on the dimmer and then off again 2 seconds later that correctly activates the door. I now have 2 questions:
(1) how do I create a virtual device that reports the state of the door (open or closed) and is able to operate the door (using the scene I have created)
(2) once this device has been created, will it be able to be operated using iVera mobile app?
Many thanks in advance
I use a plugin called Garage Door created by RichardTSchaefer, it’s available from the install apps store. It’s worked great for me, consolidates the garage door sensor and a switch (I used a Evolve LFM-20) into a single device with a lock/unlock function which is usable from iVera or Automator. No need to create a scene, it also handles the quick turn off of the switch.
Hope this helps.
Actually I only packaged the plugin and cleaned up the interface.
The idea and initial implementation was done by woodsby!
Genius - thanks!
I have installed the garage door app…
  1. How do I associate the window/door sensor to it?
  2. How do I get it to operate my device to open and close the door?
I know these are basic questions, but it isnt obvious from the settings menus.
Many thanks
[quote=“BARThompson, post:5, topic:174213”]I have installed the garage door app…
Many thanks[/quote]
A little searching on the forum would direct you to this:
http://rts-services.com/Vera/Plugin/GarageDoor/
  • Garrett
