This made me think of trying to integrate the a/c unit with EzloPi. Looking at the documentation and source code of EzloPi, it seems that each device is actually hardcoded in both the firmware and the Windows desktop application for configuration purposes.
What’s the envisioned way forward with EzloPi? Would I need to clone the git repository, develop the integration and create a pull request? And how do you keep track of the integrated devices if others start adding them?
EzloPi Board: this board will allow you to connect its GPIO to any other hardware (whether its another ESP board controlling some other a/c units or something else…EzloPi board will handle all the connectivity with cloud and so on and it will be seen in your ezlo account like a “controller”…
2)the board you need to control the a/c unit… you need to get the i/o for this unit to connect to the i/o of EzloPi board so that you can control this unit via EzloPi board using MeshBots.
Hello @jouked.
We are currently working on integration of different interfaces with EzloPi project.
For now you can send the pull request and we will review it.
Write please if you have any questions with sources.
Are you sure? After installing the MQTT plugin, there is no MQTT server running on the hub, and configuration of the plugin shows a screen which asks for a broker address.
I tried to install mosquitto locally on the hub using opkg, however the installed musl libc which is part of OpenWRT is too old to run the current mosquitto software.
Hi @jouked , @Oleh I believe didn’t get the internal server part.
So you are right, MQTT plugin right now does not have an internal server. It is just a broker.
To make it usable by other plugins either we have to add mqtt capabilities to our FW API or make it a dependency library. These were not in our recent roadmap. But if you want to use mqtt as a library and you have the packages, we can assist installing those on your hub manually if it is possible. Let us know if you need assistance on that
In MQTT terms, the server is the broker. The plugin you provide is a client. Anyway, for now I’ll get the hardware for the a/c setup and use an external MQTT broker to get things started.
I’ve setup a virtual device (a thermostat) and I’ll try to implement meshbots interacting through MQTT and copying the a/c behaviour into the virtual device. Let’s see if that works.
In the end, I feel the broker should be part of the plugin and plugin configuration. The Ezlo Hub’s proposition is to be the central hub of your smart home. A MQTT server should be part of that central hub.
Fo
