Created implementation file only
actually I wanted to create a whole plugin but as it actually is just a temperature sensor with some luup code so I did this. This will be used as implementation file for a normal temperature sensor which is a virtual device created with Vera. In the sensor I added two variables, one CurrentTemperature with value 0 and a variable devNum with value 31. devNum should point to the device ID of the real ZP3102 sensor. It is a Motion sensor which meassures temperature as well but it is not displayed in Vera. It is stored as a value/variable in the actual sensor. So the new virtual sensor should show this value and read it out of the motion sensor.
Until now I used a scene with local my_temp2 = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature",31) luup.variable_set("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", my_temp2,37) return true which ran every 5 minutes to solve this issue. As I want to learn more about my vera I thought about a plugin to do all for me. I learnt that I actually only need a implementation-file as all the other stuff is pretty standrad.
My Vera is miles away and I am a bit afraid I ll put it in a loop or something bad happens if i point the virtual temp sensor to this implementation file.[code]<?xml version="1.0"?>
local SID_TS1 = "urn:upnp-org:serviceId:TemperatureSensor1"
local devNum = luup.variable_get( SID_TS1, "devNum", lul_device )
	--devNumber of real ZP3102 Sensor
function StartUp (lul_device)
	luup.variable_watch( "UpdateLevel", SID_TS1, "CurrentTemperature", devNum )
function UpdateLevel (lul_device)
	local my_temp1 = luup.variable_get( SID_TS1, "CurrentTemperature", devNum )
	luup.variable_set( SID_TS1, "CurrentTemperature", my_temp1, lul_device )
StartUp [/code]
Maybe some of you foks can say sth about it? Is it safe to just upload it and point the virtual device to it? As it is my first Luup Code i wrote I am sure it is full of errors? I let inspire myself by multiple examples and code snippets.
You need to put the call to get devNum inside the StartUp function.
function StartUp (lul_device) local devNum = luup.variable_get( SID_TS1, "devNum", lul_device ) luup.variable_watch( "UpdateLevel", SID_TS1, "CurrentTemperature", devNum ) end
Also, did you know that the callback for variable_watch returns the new value anyway?
[code]function UpdateLevel(lul_device, lul_service, lul_variable, lul_value_old, lul_value_new)
end[/code]
Note that lul_device returned by the callback is for the device where the variable was changed. You will have to keep a local copy of the virtual device ID.
<?xml version="1.0"?> <implementation> <functions> function StartUp (lul_device) local virDev = lul_device --devNumber of virtual Sensor local devNum = luup.variable_get( "urn:upnp-org:serviceId:TemperatureSensor1", "devNum", virDev ) --devNumber of real ZP3102 Sensor luup.variable_watch( "UpdateLevel", "urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", devNum ) end function UpdateLevel (lul_device, lul_service, lul_variable, lul_value_old, lul_value_new) luup.variable_set( "urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", lul_value_new, virDev ) end </functions> <startup> StartUp </startup> </implementation>
This doesn’t work either. Error in logs:01 04/04/14 10:48:46.963 LuaInterface::CallFunction_Startup-1 device 42 function StartUp failed attempt to call a nil value <0x2be4d680> 01 04/04/14 10:48:46.963 LuImplementation::StartLua running startup code for 42 I_ZP3102virtual2.xml failed <0x2be4d680>
As this is my very first Luup-Code I would appreciate help. If I understood you correctly RexBeckett, I tried to fix the issue with the lul_device changing its value in/after “watch”…
There are a couple of small issues: You need to define virDev outside the StartUp function so it will be visible to UpdateLevel. You also need to ensure that your devNum variable gets created and handle the situation that it is empty.
virDev = “”
      virDev = lul_device
  local devNum = luup.variable_get( "urn:upnp-org:serviceId:TemperatureSensor1", "devNum", lul_device )
      if devNum == nil then
           luup.variable_set( "urn:upnp-org:serviceId:TemperatureSensor1", "devNum","", lul_device )
      if tonumber(devNum) > 1 then
      else
            luup.task("devNum not set!",1,"VTemp",-1)
StartUp [/code]
there’s already a plugin that would solve this issue for you: the “Additional temperature device” plugin MiOS Apps
Tried it, didn’t work. The Luup-Code RexBeckett “helped” me with (actually its more like he wrote it :-)) doesn’t work either. I gave up on it. I keep to the scene-stuff…
The Luup-Code RexBeckett "helped" me with (actually its more like he wrote it :-)) doesn't work either.
Something wrong with this statement. If I had written it, I would have kept debugging until it did work. ::slight_smile:
OK try this. I used this code to get the Temperature off a Monoprice motion sensor, and it worked. It’s similar to @RexBeckett code suggestion. devID variable in the device should be filled with the target device number.
<implementation>
	<functions>
		local THIS_DEVICE
			luup.variable_set("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", lul_value_new, THIS_DEVICE)
		function startup (lul_device)
			luup.log ("J: Ext temperature " .. lul_device .. " running..")
			THIS_DEVICE = lul_device
			local devid = luup.variable_get( "urn:upnp-org:serviceId:TemperatureSensor1", "devID", lul_device )
			if devid == nil then
               luup.variable_set( "urn:upnp-org:serviceId:TemperatureSensor1", "devID","", lul_device )
			if devid and tonumber(devid) &gt; 1 then
				local t = luup.variable_get( "urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", tonumber(devid) )
				if t then
					luup.variable_set("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", t, lul_device)
				luup.variable_watch( "UpdateLevel", "urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", tonumber(devid))
			else
				luup.log ("J: Ext temperature "  .. lul_device .. " devID invalid!")
	</functions>
	<startup>startup</startup>
</implementation>
