I’ve just put a plugin onto apps.mios.com that makes scriptable countdown timer devices. Combined with scenes, this plugin can eliminate the need to use Luup in several real-world scenarios.
Fetch the plugin here: Countdown timer. This plugin is UI5/6 only.
By itself, a countdown timer doesn’t do much. When the Start button is pressed, a timer counts down seconds from a (configurable) start value. Left to its own devices, when the timer hits zero, it stops.
What makes the plugin useful is that the Start button is scriptable: like a virtual switch it can be run as a target action for any scene. Any Vera event can start a timer.
There is also a Cancel button to abort a timer. That, too, can be triggered by a scene.
For more complicated scening, there is a Restart button that does exactly the same as Start, except that it resets the timer back to its start duration even if it’s currently counting down. Finally, there’s a Force button, equivalent to grabbing the kitchen timer and wrenching it down to zero (ding!).
When a timer completes, or if it’s cancelled, the timer device triggers an event. You can use this event to start a scene that can make your Vera do anything that is scenable.
Timers can be Muted, which just prevents them from generating an event. This might be useful if you want to disable a timer during a certain time of the day: it still counts down but doesn’t go Ding.
Tip for creating multiple timers: Apps > Countdown Timer > Create Another.
Some scenarios in the next post.
